Discussion topic: Broadband dropping out
This message was authored by: Emma8526
Hi, my internet keeps dropping out. We've do t the connection test and says all fine but through the day still regularly drops out until we restart the router which sometimes helps.
Re: Broadband dropping out
@Emma8526 if you pist your hub's connection stats forum members maybe ablecto tell you what is wrong see Find your Sky Broadband router statistics
Avatar for Emma8526
Thank you
Avatar for Emma8526
Would purchasing a new router such as an ASUS one I've seen mentioned help with the problem?
@Emma8526
Your line shows no drops since it was rebooted 17hrs before you posted the stats.
Your 5ghz WiFi does show a low uptime though, did you change the WiFi channel manually at all?
I am NOT a Sky Employee
