Discussion topic: Broadband dropping out constantly
This message was authored by: MichaelC68
This week I have encountered multiple broadband dropouts and now I am unable to stream tv such as BBCi player. The sky app says all is good? I have done all the steps suck as plug and unplug everything and restart. Sky, please can you fix this problem?!
Re: Broadband dropping out constantly
@MichaelC68
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Avatar for MichaelC68
Level 0 icon
I have as said in my message done these checks and it's not working. Thanks
@MichaelC68
Then you'll need to contact Sky and report it.
