Discussion topic: Broadband dropping out again
This message was authored by Emyr This message was authored by: Emyr
Hello, our broadband keeps dropping out and is getting worse/more frequent again similar to before. I've unplugged the box and left it. Pressed reset but it's been doing it for the last week or so
This message was authored by johnm1959 This message was authored by: johnm1959
Re: Broadband dropping out again
I have the same problem. all product tests show OK. I suspect the line into my property has a bad connection and is dropping in and out. what . was your solution?
This message was authored by Sam2909 This message was authored by: Sam2909
Same as above - sky broadband speed test says all is good, yet others speedband tests say different and they all give similar results which is no way near what sky says is delivering
Emyr
I'm suspecting an issue with the line in. They've already given me a new box. Nothing showing as an issue online or via the app. I need to call them but now can't fond the number
