Discussion topic: Broadband dropping off
This message was authored by: Kisan
My broadband keep on dropping off. When do a check it says everything is ok. I know it is not working because I lost WiFi signal Kisan Visavadia
Re: Broadband dropping off
@Kisan
When you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
