Discussion topic: Broadband dropping connection
Message posted on 08 Dec 2025 12:23 PM
The internet connection has been dropping and buffering for the past 3 weeks
Message posted on 08 Dec 2025 12:34 PM
Re: Broadband dropping connection
@Jatsby Have you called sky about it, the Forum is not sky Customer Service when you post! You can also run the test your end so link below if you need!
Try running the line test here to see if any faults are found:
