Discussion topic: Broadband down
This message was authored by: Grace551
Broadband down
My Broadband went down overnight and is still down. This is the third time this has happened in a week. What is going on at Sky? Furthermore, I can't even do the "fix broadband" function on the Sky website as it keeps circling like it is overloaded with requests. Please help!
Re: Broadband down
@Grace551
You aren’t talking to Sky by posting here. If you are new to the forum then welcome to the Community which is made up predominantly of Sky customers helping other Sky customers with additional help from Superusers like myself.
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
