Discussion topic: Broadband down
Message posted on 22 Jul 2026 11:24 AM
Broadband down
Message posted on 22 Jul 2026 11:26 AM
Re: Broadband down
Re: Broadband down
@Andrea532 @Sdpnk First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Message posted on 26 Jul 2026 05:03 AM
Re: Broadband down
Thank you for the response. Turned out there was a fault, caused by work being done: quite a few people had issues, which was later recognised by Sky.
Ps. I had already done the things you suggested. Thank you anyway.
