Discussion topic: Broadband down
Message posted on 10 Jan 2026 03:06 PM
Broadband down
Message posted on 10 Jan 2026 03:10 PM
Re: Broadband down
@macavoy
See further down for guidance on hub lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
