Discussion topic: Broadband down.
This message was authored by: Dave02672
Broadband down.
No internet for at least the last hour.
the broadband and WiFi check on MySky says everything is working fine but it clearly isn't.
I have tried turning my router on and off but it's no different.
Re: Broadband down.
The checker isn't the quickest as picking up a fault so it is worth running it again later if you can in the meantime try running this line test to see if it finds any faults:
If this is of no help give Sky a call to report it to them.
