Discussion topic: Broadband down
This message was authored by: Karen--
Broadband down
My broadband has stopped working this morning.What can I do, I have ran all checks and no problem found
Re: Broadband down
@Karen--
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
