Discussion topic: Broadband down
Message posted on 24 Jun 2025 02:08 PM
Broadband down
Hi,
My Internet has dropped and is not working. This is the 2nd time this week. Tested the line and everything is showing good. Power light and WiFi are showing as green. Voice is orange and Internet no light at all.
Can this please be investigated as a matter of urgency as I work from home.
Message posted on 24 Jun 2025 02:33 PM
Re: Broadband down
@Matt281
This is predominantly a customer led discussion forum where Sky customers are available to help other customers. You aren’t contacting Sky Customer Services by posting here.
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
