Discussion topic: Broadband down
Message posted on 21 Jun 2025 09:03 AM
Broadband down
My broadband isnt working. The app says that its fine. Then says theres a problem. Then tells me its fixed. Then its down again.
Message posted on 21 Jun 2025 09:14 AM
Re: Broadband down
@danroadley If it is all just started happening could be anything, the sky service checker will say if THEY do have an idea what the problem is when they know, if it is just your connection then diagnostic may find it and if not then it is a call to sky for them to test.
Try running the line test here to see if any faults are found:
