Discussion topic: Broadband down
This message was authored by: Leahmcc
Broadband down
The past 3 days my internet has been going on and off and now it has completely turned off and not coming back on I am not entirely happy with these circumstances as I have paid for the month and it's been on and off for a few days now I would like to speak to someone over the phone
Re: Broadband down
@Leahmcc
That would mean you calling Sky.
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
Its worth adding that for customers working from home remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
Re: Broadband down
@Leahmcc
 Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them. 150 is the free number to use from a phone that has a Sky mobile sim in it or Sky Talk phone otherwise under "Need more help ?" link at the bottom of the page on this link is the number to call Sky on:
https://www.sky.com/help/home
Try saying nothing when spoken to by the bot.
