Discussion topic: Broadband down
This message was authored by: Dos4
Message posted on 07 May 2025 06:19 PM
Broadband down
The broadband keeps going off
Find out more
Message posted on 07 May 2025 06:20 PM
Re: Broadband down
@Dos4 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
