Discussion topic: Broadband down
Message posted on 20 Jan 2025 04:00 PM
Broadband down
Internet has been on and off all day, now not working at all. Have tried all usual steps. Have run a check and it's saying everything is fine!
Message posted on 20 Jan 2025 04:28 PM
Re: Broadband down
Mines doing the same in Amersham, Buckinghamshire
Message posted on 20 Jan 2025 04:37 PM
Re: Broadband down
