Discussion topic: Broadband down
This message was authored by: Mel120
Broadband down
My broadband is not working and has been on and off for over a week. This is unacceptable. I've run a check on the app which says everything is working however there are only two lights on the box and nothing is working
Re: Broadband down
@Mel120
What have you tried so far, have you rebooted your broadband hub at the mains, if this doesn't fix it then try running the line test here:
