Discussion topic: Broadband down
This message was authored by: JoMottie72
Broadband down
Hi is anyone else having an issue with their broadband tonight 2/11/24 I've done all the tests and everything and it's saying it's fine
Re: Broadband down
@JoMottie72  the standard advice is to check the lights on the the hub which you have done -see https://www.sky.com/help/articles/hub-lights-explained-start - If they show the hub has lost connection to the line and a simple reboot doesn't sort the issue is to log into the My Sky app and see if the service checker tells you Sky are aware of a fault affecting your line. Don't worry if it says everything is fine as that was the position when it last tested the service.
If it doesnt tell you it's a known fault call Sky their lines are open from 8am to 9pm
