Discussion topic: Broadband down regularly
Message posted on 15 Aug 2025 09:12 PM
Our broadband keeps cutting out regularly
Message posted on 16 Aug 2025 05:36 AM
Re: Broadband down regularly
@Colly3
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
