Discussion topic: Broadband down in Bury
This message was authored by: Twopants68
Hi, I have "Supefrast" Broadband, is anyone else's wi fi completely dead in the Bury/ Greater Manchester area? I'm getting no signal whatsoever... I also had a new hub delivered this week but still no green light. I've got an engineer coming next week but I just wondered if it was off anywhere else.
Thank you
Re: Broadband down in Bury
@Twopants68
At any given time there might be thousands of customers without broadband. Sky have in excess of 7 million broadband customers so there's always likely to be faults or outages.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Avatar for Twopants68
Thank you, it does say there's an outage, it's been like that for a few days now but I've not had any correspondence from Sky, I usually get a text or something. Probably no point in an engineer coming.
I've got offers from Virgin on standby as the can provide fibre on my block and Sky can't
