Discussion topic: Broadband down for over 12 hours
Message posted on 23 Nov 2024 07:55 AM
My broadband is down and has been down for over 12 hours.
Checking on local media I can see no other complaints or comments.
Is anyone else experiencing this issue in the Cosham area?
Message posted on 23 Nov 2024 08:18 AM
Re: Broadband down for over 12 hours
@Lozzmeister you are best advised to check here No connection or slow WiFi | Sky Help | Sky.com | Sky Help | Sky.com
using a mobile connection as that should tell you if Sky are aware of an issue in your area. If they aren't give them a call to report the issue to get it fixed.
Message posted on 24 Nov 2024 08:49 AM
Hi, yes mine has been down in cosham as well. Been 36 hours now! Sky will just send you to service checker that tells you there is a local outage bit doesn't give you any indication of when it will be fixed or any regular updates which is frustrating. I hope it gets sorted today as this is ridiculous.
