1
This discussion topic has been answered Discussion topic: Broadband down eh14
This message was authored by: DC66z
Broadband down eh14
Broadband suddenly went off approx 39 mins ago. Powered off/on. Power ok but no broadband/wifi
Re: Broadband down eh14
@DC66z
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
@DC66z
