This discussion topic has been answered Discussion topic: Broadband down again
Message posted on 01 Jul 2026 06:40 PM
Hi,
Broadband was ok in the cooler weather for a few days but it has tripped out again. It's not your equipment as we have tried a different router, but no success. As per my last conversation, can we get an Openreach out as 13 days without broadband isn't acceptable?
Roger Johnson
Message posted on 01 Jul 2026 06:58 PM
@rog11111
You may not be aware but you haven’t contacted Sky by posting here. This is primarily a customer ▶️ customer discussion forum where we try to assist other customers.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
@rog11111
