Discussion topic: Broadband down Knocklyon
Message posted on 30 Nov 2025 12:37 PM
Broadband not working in Knocklyon
Message posted on 30 Nov 2025 01:03 PM
Re: Broadband down Knocklyon
@Broadbanddown1
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Message posted on 30 Nov 2025 01:04 PM
Having now discovered you live in the ROI those links may not be relevant.
