Discussion topic: Broadband disconnecting
Message posted on 10 Jun 2026 06:58 PM
My broadbanding is dropping across all devices but no impact to sky on tv, is there anything i can do to fix it.
Message posted on 10 Jun 2026 07:26 PM
Re: Broadband disconnecting
@Deirdre14 wrote:My broadbanding is dropping across all devices but no impact to sky on tv, is there anything i can do to fix it.
That sounds like a WiFi issue? Is the Sky box wired to the router?
Have a look at the following to see if they can resolve your problem easily. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used).
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
