Discussion topic: Broadband delivery
This message was authored by: Sinto
Broadband delivery
I purchased a broadband on 27/11/25 and it has not arrived yet. When I click track order it's showing as "There is an issue with your order please contact us ". I tried to contact them a lot but call was not connecting. What should I do to get my broadband?
Re: Broadband delivery
@Sinto
You need to contact Sky (see below).
Hubs for new activations are normally dispatched via Royal Mail to arrive a few days prior to the activation date.
Once sent out you can usually track its progress. The postie will usually leave it hidden if no one is in. You don't need to sign for it. The postie should also pop a card through the letterbox telling you where it was left and the tracking should show some information on it too.
These are the current methods for contacting Sky. Depending on the reason for making contact some methods will be more appropriate than others …
🟧 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you already have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟧online help via this link
https://www.sky.com/help
🟧Sky Assistant 💬 should also be available via
🟧Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
