Discussion topic: Broadband current outage
Message posted on 05 Oct 2026 06:17 AM
Currently experiencing an outage in KY11 postcode , now been at least 25 hours and need service for work Monday morning, is there and estimated time for the service to be resumed?
Message posted on 05 Oct 2026 07:17 AM
Re: Broadband current outage
@Userinamillion area outages are usually within the Openreach or City Fibre networks and will be being worked on by their engineers not by Sky themselves. Usually there is no way of getting more than a guess to how long it will take to be resolved. Someting over 85% are sorted within 2 full working days (which excludes weekends if the issue only affects domestic lines) it all depnds on the cause which can often be damage like a car hitting a pole or a digger driver damaging a buried cable.
You will start to accrue compensation if the repair takes longer as explained here Customer Auto-Compensation | Sky Help | Sky.com That you use your connection for work gives you no priority which is the disadvantage of relying on a domestic line for work. It is sensible to have a fall back plan
Message posted on 07 Oct 2026 12:07 AM
Thanks for the reply
it's now been over 48 hours and still no broadband , how do I find out that they definitely know there is a problem and they are working on it ?
Message posted on 07 Oct 2026 05:38 AM
The first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If nothing shows then try this line test:
