Discussion topic: Broadband conversion kit
Message posted on 24 Aug 2026 04:40 PM
Hi,
I am having full fibre installed In two weeks. I have a Sky Q router. I have received a broadband conversion kit today. Do I keep this until fibre is installed?
Shirley Ann
Message posted on 24 Aug 2026 04:41 PM
Re: Broadband conversion kit
Hi @redcat53
The conversion kit is usually just an ethernet cable to connect your hub to the new ONT that will be installed when you get full fibre. Keep it handy until your activation date and then you can use it to connect your hub.
Message posted on 28 Aug 2026 08:57 AM
Thanks so much- appreciate it.
Shirley Ann
