Discussion topic: Broadband conversion kit 1
Message posted on 15 Jul 2026 05:14 PM
Hi please can you help me had a text from sky today that I am being sent a broadband conversion kit 1 (which I believe is just a cable) but I don't have a optical network terminal (ont) nothing has been mentioned about if an open reach installer has been booked or if I need an (ont) please can someone advise me many thanks
Message posted on 15 Jul 2026 05:25 PM
Re: Broadband conversion kit 1
If Openreach are due to visit to install the fibre connections for you then the conversion kit is just a a cable that will be needed to connect your broadband hub to the ONT which should be installed by Openreach or if you are in there area then it will be Cityfibre.
Do you see anything here regarding your order:
https://www.sky.com/ordertracking
Message posted on 15 Jul 2026 05:45 PM
Just says kit posted nothing at all about an engineer visit
Message posted on 15 Jul 2026 07:46 PM
Do you see an activation date shown on your account ?
If it is Openreach doing the work have you received any emails from them ?
Message posted on 15 Jul 2026 09:40 PM
29th for activation no email from openreach
Message posted on 15 Jul 2026 10:11 PM
When did you place the order ?
Message posted on 16 Jul 2026 07:50 PM
14th july
Message posted on 16 Jul 2026 08:00 PM
If your activation date in the 29th July then Openreach or Cityfibre will either turn up on this day to do the work or a few days earlier.
