Discussion topic: Broadband continually dropping
This message was authored by: jd13762
I am getting very frustrated with the continual Broadband drop as it is causing me concerns with my working activity.
Avatar for jd13762
Re: Broadband continually dropping
Repeats every 10 minutes, and periodically resolves itself..
@jd13762
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
