Discussion topic: Broadband connection
Message posted on 11 Sep 2026 06:04 PM
My broadband was connected today and it's showing red lights
Message posted on 11 Sep 2026 07:39 PM
Re: Broadband connection
As you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
