Discussion topic: Broadband connection
This message was authored by: stephen+glenn
Message posted on 04 Oct 2025 12:06 PM
My broadband is intermittent. It connects to phones then drops out and will not connect to the TV
Message posted on 04 Oct 2025 12:07 PM
Re: Broadband connection
I've reset everything many times and still it won't connect
Message posted on 04 Oct 2025 01:11 PM
@stephen+glenn Is it a wi-fi connection issue only, and the broadband is up and working fine! The two links below may help you, If you have a sky Max then start with the bottom one first!
sky connecting devices
https://www.sky.com/help/articles/connect-devices-to-broadband-start
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
