Discussion topic: Broadband connection
Message posted on 20 Sep 2025 06:04 PM
The broadband connection is not working so the landline, my apps, and the sky q mini box is not working
Message posted on 20 Sep 2025 06:09 PM
Re: Broadband connection
@Tigers
Use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
