Discussion topic: Broadband connection
This message was authored by: EJTay
The broadband keeps dropping out. It has
done it all week. It's so frustrating as i work from home and my work is cloud based. Please help
Re: Broadband connection
@EJTay
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
