Discussion topic: Broadband connection
This message was authored by: Mattielane1979
Hi, I recently moved house and called on Saturday the 2nd for help and was told that the issue would be resolved in 72 hours , it's the outside line that is at fault
Has this been resolved now ? I am in work so can't see the router tk check
Re: Broadband connection
@Mattielane1979 No one on the Forum would know that answer, but you will find it out as soon as you get home, if not and sky are still open then call them to find out what is going on!
