Discussion topic: Broadband connection keeps dropping
Message posted on 28 Apr 2026 11:15 PM
Broadband keeps cutting out. Voice light on hub turns orange
Message posted on 29 Apr 2026 05:17 AM
Re: Broadband connection keeps dropping
@TP18
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
