Discussion topic: Broadband connection issue
This message was authored by: Gavin1968
Just got back from holiday. My router is on but lights not all green. 2nd & 4th from the left are orange .
the screen says there is a problem with the broadband but when I test using the app it says it is all ok! It isn't
please help to get this sorted
Re: Broadband connection issue
@Gavin1968
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
