1
This discussion topic has been answered Discussion topic: Broadband box not working
This message was authored by: Ed303
Hi, our broadband box only has the power light (left side one) on solid green. I have tried to hard reset but there is still no change.
please can you advise.
Re: Broadband box not working
@Ed303
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
@Ed303
