Discussion topic: Broadband appears to work but keeps droppings and streaming buffers
Message posted on 12 Dec 2025 07:16 AM
Broadband appears to work but keeps droppings and streaming buffers on phone, Netflix and other devices
Message posted on 12 Dec 2025 12:16 PM
Re: Broadband appears to work but keeps droppings and streaming buffers
@Mikecarey84 you need to determine if the issue is your broadband connection or simply flaky wifi in your home. The former can be checked by the service checker in the My Sky app which checks the speed daily. If thst has dropped below the guarantee it should offer help.
If that is OK then your issue is likely to be poor WiFi in your home. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
