Discussion topic: Broadband and phone down
This message was authored by: Fredhead999
Broadband (standard phone line) and phone down - SS17 8). MySky says no problem to my property and no local issues!
Re: Broadband and phone down
@Fredhead999
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
Avatar for Fredhead999
Thanks - it was a Sky/Openreach problem - all working again this morning
