Discussion topic: Broadband and internet down
Message posted on 30 Aug 2024 11:10 AM
My broadband and internet have gone down. I have a black router. The power light is green. The internet light is amber. The WiFi light is green. There is no light for voice. Please can you help?
Message posted on 30 Aug 2024 11:15 AM
Re: Broadband and internet down
@PJ4T Try the steps here https://www.sky.com/servicechecker
Message posted on 30 Aug 2024 11:19 AM
I have already done the service checker which suggests everything is fine. I have unplugged the router and switched it back on. I have pressed the rest button once. I have pressed and held the reset button for 20 seconds. The lights I mentioned above are what is showing after having done all this.
Message posted on 30 Aug 2024 11:37 AM
Message posted on 30 Aug 2024 11:50 AM
@PJ4T Cna you follow through on the latter directions of the help below as the service checker shows you historical data and the majority of the time will say all good.
Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
Message posted on 01 Sep 2024 01:21 PM
Thanks for your suggestions. In the end I rang Sky help desk and they identified a problem and booked an engineer for Tuesday.
However today the service has thankfully been restored.
