Discussion topic: Broadband and WiFi
This message was authored by: Cezzer77
Broadband and WiFi
We upgraded to Sky Full Fibre 150 at the end of last year and since then we've had a lot of brobkems with the internet and WiFi dropping out.
We've tried all the resets listed on the Sky website numerous times but it's now getting worse. My wife works from home and it's now affecting her job.
Re: Broadband and WiFi
@Cezzer77
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
