Discussion topic: Broadband and WiFi not working
Message posted on 27 Oct 2025 11:18 PM
My internet has gone down again, all day and I've don't the checker most of the time says it's fine I have screenshots of the service down
Message posted on 28 Oct 2025 05:22 AM
Re: Broadband and WiFi not working
@Mr+G+Henry
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
