Discussion topic: Broadband. Wifi not working
This message was authored by: Kazzy01
Broadband/WiFi not working. Anyone else?
Re: Broadband. Wifi not working
@Kazzy01
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your devices and your hub. Broadband is the actual internet connection provided by your ISP (Sky).
If your broadband isn’t working use this link to check to see if there are any problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update).
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Kazzy01
Thank you for that...I have tried the sky service check and it says its good...
@Kazzy01 wrote:
 Anyone else?
Sky has around six million broadband subscription households: that kind of scale means at any particular point in time thousands of the individual Openreach circuits supplying those properties will have faults.
The service checker looks for outages in you area so what was the result of the line test ?
