Discussion topic: Broadband / WiFi
Message posted on 09 Dec 2025 10:31 PM
Broadband / WiFi
Please check my services as my appliances are struggling to connect to the WiFi/internet
I have reset allhubs/puk etc but still get the spinning wheel.
Message posted on 09 Dec 2025 11:07 PM
Re: Broadband / WiFi
@JCF2
You aren’t contacting Sky here. This is a customer ▶️ customer discussion forum where we try to help other customers.
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
