Discussion topic: Broadband WiFi not loading / working
Message posted on 04 Jul 2026 05:32 PM
Hi, I'd like to report that my WiFi is slow, not loading videos and I can't browse or sign into anything on my WiFi.
I have switched it off and re set few times.
can someone help?
thanks,
sertac
Message posted on 04 Jul 2026 05:35 PM
Re: Broadband WiFi not loading / working
What is your wifi signal like, if it is weak then a poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
