Discussion topic: Broadband Speed
Message posted on 02 Feb 2026 10:38 AM
Broadband Speed
Message posted on 02 Feb 2026 11:08 AM
Re: Broadband Speed
@DanNelly What is your connection meant to be for speed, and how do you know that bonkers.ie is working OK, check other sites for speed testing to try and eliminate were the issue is, ie external to the home or internal, and yes your values are correct that is what is being returned and can happen for many many different reason's... I have seen my Android phone return 17Mb/s - 70Mb/s down/up rate when i had a poor wireless wifi signal which required an additional AP to fix that out! Phone was relevant because when it went down speed wise it would just never ever recover until the wireless was switched off on it, as soon as back on straight back to the 1200Mb/s sync speed and full Up/Down for me which was FF500 so 500/70Mb/s on testing!
