Discussion topic: Broadband Setup
This message was authored by: samwalton13
Broadband Setup
i’m getting sky broadband set up and when i purchased it asked if i have a current landline and telephone and i selected no, but we do have broadband with virgin media but we also want sky too, im just checking to make sure that the sky installation wont mess with the virgin media broadband that i currently have, ive read that they use different lines, thanks
Re: Broadband Setup
@samwalton13 With the fact you said no then VM will not be touched Broadband wise, just not sure about the telephone connection side, so sky will issue you a new number against your new Broadband connection now but they should no if there is an OR line and what is going to be involved with that side, and you will not be doing any swapping in the future with the VM phone line as that may get way complicated!
You are also have to be carefull with having two broadbands in the same area's for any wireless wifi clashing and band control!
