2
This discussion topic has been answered Discussion topic: Broadband Outage
This message was authored by: BradC23
Broadband Outage
My internet has been down since 4am (Ip8 area of Ipswich). I was hoping it would be back up and running as stated within 48hrs on the sky assisstance. Does anybody have any idea how to check progress or even have a number to call for some clarity.
Re: Broadband Outage
@BradC23
Where are you seeing 48 hours mentioned?
If you haven’t done it yet you can use this link to check to see if there are any broadband issues or outages nearby.
Note: It doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps retry later.
Sky normally quote 2 WORKING DAYS as a potential fix time. This is the service level agreement in the UK between ISPs and Openreach for fixing a fault as Openreach claim to be successful within that timeframe in about 85+% of cases.
@BradC23
Avatar for BradC23
Hi Daniel,
apologies it went out 4am on 26/10/25, with sky stating "there is an outage in your area, it is usually sorted within 48 hours though maybe sooner"
