Discussion topic: Broadband Not work
Message posted on 26 Jun 2026 11:56 PM
Broadband Not work
The broadband just keeps on disconnecting, even after fixing it, it disconnects, now the broadband is fully red and not working
Message posted on 27 Jun 2026 05:19 AM
Re: Broadband Not work
@Grigore_Goie
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
