Discussion topic: Broadband - Light not on
Message posted on 05 Oct 2025 08:03 AM
Hello,
my broadband has now not been working for 2 days, turned off and on numerous occasions and no luck, I've tried to speak to an advisor keep getting the virtual assistant, can't find a phone number anywhere for help...it's like the router is completely broken, no light appears when I turn the box on, anyone had any similar issues and does anyone know how to fix this?
Message posted on 05 Oct 2025 08:11 AM
Re: Broadband - Light not on
@ConradSmi781
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour later).
